My X350 audio upgrade with lots of photos (sorry, no audio)
Hey guys, I wanted to share with you my latest improvement made to my x350's in car entertainment system.
Before I started, my car had the premium system, components up front (dash mids, door handle supertweeters, and door midbass) and in the rear - door midbass and those handle supertweeters. Of course, I have the ACM installed.
After I bought the car a couple years ago, I immediately added a 10-inch JL subwoofer in a sealed box, and powered it with a JL Audio mono amplifier and an AudioControl LC2i to take the subwoofer leads from the existing amplifier, sum them into one channel, and compensate for the system's tendency to 'reduce bass' at higher volumes. I was fairly satisfied, but something kept nagging at me, it just wasn't hitting very hard, and I was very disappointed from a rear-seat passenger not having any midrange back there. If you wanted to hear vocals, it had to come all the way from the front dash. So, I came up with a plan.
You should see my electrical wiring diagram with notes and connections!
My shopping list included:
RE Audio xxx6.5c components for the front and rear
![](http://matt.zenfolio.com/img/s12/v182/p404100473.jpg)
AudioControl LC7i output converter with bass restoration
![](http://matt.zenfolio.com/img/s3/v44/p721112047-2.jpg)
Precision Power DEQ.8 signal processor
![](http://matt.zenfolio.com/img/s2/v70/p459489411-2.jpg)
JL Audio XD400v2 4-channel amplifier
![](http://matt.zenfolio.com/img/s12/v183/p332841844-2.jpg)
PAC Audio LC-1 remote level control for the subwooer gain adjustment
![](http://matt.zenfolio.com/img/s12/v183/p152400711.jpg)
And I incorporated my existing amplifier and subwooer:
JL Audio 500/1 version 1 mono amplifier
![](http://matt.zenfolio.com/img/s12/v174/p310990411-2.jpg)
JL Audio 106v2 subwoofer in a sealed box
![](http://matt.zenfolio.com/img/s3/v41/p491593713-2.jpg)
The project scope was daunting, but after I bought all of the equipment, I couldn't stop my momentum.
I removed almost everything from the interior...driver seat, center console, rear seat w/ the rear entertainment armrest, rear parcel shelf...so much trim...it was two days just getting it disassembled.
![](http://matt.zenfolio.com/img/s5/v132/p210000816-4.jpg)
![](http://matt.zenfolio.com/img/s12/v179/p603941089-4.jpg)
Here is my interior...totally stripped!
![](http://matt.zenfolio.com/img/s12/v182/p352988610-4.jpg)
The driver seat was a total beeetch to get totally unfixed from the car...the seat belt strap and mounting bolt was behind the trim, and you had to tilt it back to get the last screw on the trim piece, then move the seat forward far enough to get the ratchet and torx on it! what a pain in my rump...but totally worth it.
![](http://matt.zenfolio.com/img/s5/v117/p735995336-3.jpg)
![](http://matt.zenfolio.com/img/s12/v183/p1025228802-3.jpg)
Now, I used some of the existing wiring to the speakers, but I also added new speaker wires to the rear for my 'new' tweeters (for the missing midrange frequencies). When I got into the doors, each supertweeter was just disconnected...no need for those anymore.
Removed the old subwoofers from the rear parcel shelf...I think it helped the lower frequencies to make it into the cabin.
![](http://matt.zenfolio.com/img/s6/v139/p1002625935-4.jpg)
![](http://matt.zenfolio.com/img/s5/v116/p897580472-4.jpg)
Why the driver seat and console, you ask? Well, I wanted to run the subwoofer amplifier remote gain/level control knob and its bass boost (set at 52 hz) I installed them both inside the ashtray compartment![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
![](http://matt.zenfolio.com/img/s12/v184/p543527784-4.jpg)
The PPI DEQ.8 signal processor also is controlled/adjusted using a USB interface, so I ran a long cable up to the front, coming up under the driver seat so I can easily plug it into my laptop for tuning while in the 'prime' listening position.
Notice anything different to the rear doors?
![](http://matt.zenfolio.com/img/s12/v170/p842054798-4.jpg)
![](http://matt.zenfolio.com/img/s7/v152/p731541011-4.jpg)
That's where I installed the new tweeters! I didn't want to do the original shiny black look, so I could either go light and try get close to the ivory interior, or a little darker and contrast it slightly. I chose the 'darker' route.
![](http://matt.zenfolio.com/img/s10/v102/p481492295-4.jpg)
In the boot, things got a little tight on space trying to locate all the crossovers (yes, I wanted to put them all back here instead of near each of the components...personal preference), output converter, signal processor, and those amps.
I put the signal processor atop my BT/phone module combo in the equipment rack...perfect fit!
![](http://matt.zenfolio.com/img/s5/v121/p525227553-4.jpg)
![](http://matt.zenfolio.com/img/s3/v40/p342221666-4.jpg)
![](http://matt.zenfolio.com/img/s7/v167/p526109968-4.jpg)
The output converter, I chose to affix it to the existing amplifier, since I needed close proximity to all those original speaker level inputs
Initially, I didn't think I would need this particular converter, but here is what I found when I 'tested' each existing speaker wire for its range.
Before I started this little venture, I read from another member's post that he discovered that each speaker wire carried a 'full' range signal to each speaker, and the speaker itself had resistors mounted to cut various frequencies from the speaker itself. Well, that wasn't the case for me. Here is what I found.
Front dash - upper frequencies only
Front doors - lower frequencies only
Rear doors - full range
Isn't that odd! So, instead of four (4) channels to work with, I had six (6). The AudioControl LC7i accepts six (channels) and allows you to sum all six, four, or none at all into the MAIN channel 1, giving me my four (4) inputs I wanted into the DEQ.8...plus, the LC7i it allowed me to 'catch' and correct the system's higher volume bass drop-off. I don't know if it only applied to the subwoofer, but I had a suspicion it also dipped the low-end in all the door midbass speakers.
So, after putting the interior all back together, and spending a few weeks tweeking the signal processor's, it sounds fantastic. The tuning capability of the front EQ and the sub frequencies make a huge difference over the stock system curves. Here are some screenshots of the user interface for the processor. It was pretty user friendly.
![](http://matt.zenfolio.com/img/s5/v125/p535115533-3.jpg)
![](http://matt.zenfolio.com/img/s12/v172/p424380210-3.jpg)
![](http://matt.zenfolio.com/img/s5/v120/p327989490-3.jpg)
![](http://matt.zenfolio.com/img/s2/v73/p518768084-3.jpg)
![](http://matt.zenfolio.com/img/s5/v132/p106618721-3.jpg)
![](http://matt.zenfolio.com/img/s8/v74/p304673130-3.jpg)
Its 'fuller', vocals are strong, and I can get some serious low-end bass, although the tighter drum-type 'punch' is hard to feel all the way up front from the boot in this LWB car. As such, I used the RE Audio components to take some of that duty...did you see the magnet on this thing?
It is a very good speaker system, and even with the 3/4" spacer added, my rear windows contact the magnet at the end of its travel.
![](http://matt.zenfolio.com/img/s12/v175/p953179311-4.jpg)
![](http://matt.zenfolio.com/img/s7/v164/p920308465-4.jpg)
![](http://matt.zenfolio.com/img/s7/v162/p783456371-4.jpg)
Oh, and the BT phone volume is no longer too low to hear! This was a complaint that me and another member identified, and with the new amp setup, my phone volume is never over 3/4 of its range. A bonus...and so much better!
I'm just now getting my carpet installed back into the boot, so no final pictures just yet of what is visible. But, in the meantime, here is a work-in-progress shot![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
![](http://matt.zenfolio.com/img/s12/v171/p966350281-4.jpg)
![](http://matt.zenfolio.com/img/s7/v153/p955706639-4.jpg)
![](http://matt.zenfolio.com/img/s6/v140/p597411654-4.jpg)
There is so much involved with this install, if anyone has any questions, just let me know. I have more pictures and can explain any details that I missed after glossing over the project in general here.
Now, if you've read this far...anybody want 6-3/4" midbass drivers? Free, you pay for shipping. All work perfectly...just pay for shipping!
![](http://matt.zenfolio.com/img/s5/v124/p106962416-4.jpg)
![](http://matt.zenfolio.com/img/s6/v140/p118846449-4.jpg)
I didn't salvage the mids in the dash, as I destroyed them to 'drop' in the RE Audio tweeter into the frame of the dash mid, allowing me to use the same mounting bracket and I soldered into the speaker connector too!
![Icon Naughty](https://www.jaguarforums.com/forum/images/smilies/icon_naughty.gif)
![](http://matt.zenfolio.com/img/s10/v108/p335588029-3.jpg)
![](http://matt.zenfolio.com/img/s6/v150/p896897891-4.jpg)
The following 17 users liked this post by H20boy:
abonano (07-28-2014),
AD2014 (07-26-2014),
anindyam (07-26-2014),
biggieslicky (07-28-2014),
Cambo (07-25-2014),
and 12 others liked this post.
Well, that's certainly an upgrade!
Where's part II ?
EDIT
It was the X-Type Premium Sound Retrofit that had full range going to the tweeters, but i'd fitted an amp from an X350 and it was still full range to the tweeters...and after buying a set of OEM Alpine tweeters that's when I discovered they were using the capacitor to cut the bass out of the channel.
And the p/n for the tweeter is the same for the X-Type and the XJ, so who knows...
I never got as deep into it as you, serious stuff.
Where's part II ?
EDIT
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Mine RH indash mid has quit working, it's resistance is less than 1Ohm now
If anyone have a used RH or LH dash speaker i'll be glad to buy it (paypal/whatever else).
Thanks, guys. I'm glad you approve and like my modifications
I'm really surprised that i didn't create any electrical issues when it was all put together...so many plugs, connectors and wires. I did find that the whole system won't work without the rear armrest powered and its fiber optic plug connected. I almost crapped myself when I went to test it and got NOTHING ![Icon Eek](https://www.jaguarforums.com/forum/images/smilies/icon_eek.gif)
sorry, moscowleaper, I hope you find a replacement. Ebay US has several, but the shipping charges are 3x what you pay for the part.
The following 5 users liked this post by H20boy:
AD2014 (09-16-2014),
anindyam (07-29-2014),
geberhardt (09-22-2014),
lcmjaguar (07-28-2014),
oilstain (09-12-2014)
I suppose you could try to install it behind the door handle. Its grille opening is 1-inch in diameter and the new tweeter has a diameter of 1.5 inches. May or may not have enough room behind it...I'm not sure. One thing I found about these tweeters in my past installation with the xk8...where I initially mounted it in the A-pillar facing the driver almost directly, is that sounded too 'bright'. In that instance, dash install was the best. I also read that keeping the tweeter component close to the midbass/woofer for best sound quality.
BlackKat (07-30-2014)
Nicely done. I'll be looking at doing something similar, I'll have to do some research into the outputs of my current amps (premium system). I hope somewhere there is a full channel, or at least low fq. I currently took the output from the subwoofer amp and ran that to an old Phoenix Gold amp. I'm running a decent sub, but it sounds like it's crossed over at 50hz or so. Most likely done to protect the piddly little subs that came in the rear shelf, but essentially means no proper low fq sound.
Cmon, Jaguar, how am I supposed to watch the Matrix without real bass?
Edit: Wait, I just saw that you have a SuperV8 too. So, does that mean you didn't mess with the output of the sub amp as an input at all? Just the rear had the low fq needed?
Thanks,
Oilstain
Thanks,
Oilstain
Couple more questions:
Did you try running without the PPI DSP?
Did the spacers come with the RE xxx6.5 components?
Were the spacers necessary for the front doors, or just the back?
I've read that the RE speakers are real power hogs, how do they sound with "only" 100 w/channel? (The speakers are 2ohm, correct?)
Edit to add: How difficult is removing the dash grills to retrofit your tweeters? Any tips or tricks?
Thanks,
Oilstain
Thanks,
Oilstain
![](http://api.viglink.com/api/click?format=go&jsonp=vglnk_jsonp_14108156858769&key=d92373423436cd6f57cd0cabc6847854&libId=edbbce9c-b2e0-46bf-ab01-480ca82e0603&loc=http%3A%2F%2Fwww.jaguarforums.com%2Fforum%2Fnewreply.php%3Fdo%3Dnewreply%26p%3D1057522&v=1&out=http%3A%2F%2Fmatt.zenfolio.com%2Fimg%2Fs12%2Fv172%2Fp424380210-3.jpg&ref=http%3A%2F%2Fwww.jaguarforums.com%2Fforum%2Fxj-x350-x358-xj6-xj8-xjr-28%2Fmy-x350-audio-upgrade-lots-photos-sorry-no-audio-122700%2F&title=Jaguar%20Forums%20-%20Jaguar%20Enthusiasts%20Forum%20-%20Reply%20to%20Topic&txt=)
I did not, sorry, except to begin the 'tuning', which sounded like crap initially.
No, the spacers were purchased from PVC Speaker Adapters - CNC Machined - In Stock or Custom Made for $25 each set.
I am pretty sure the front does need them also, but I started at the rear and they barely fit w/ the spacers, meaning the glass not hitting the magnet...so I chose to use them up front w/o checking first for clearance.
![](https://www.jaguarforums.com/forum/attachments/xj-xj6-xj8-xjr-x350-x358-28/95818d1410816547-my-x350-audio-upgrade-lots-photos-sorry-no-audio-screw.jpg)
