Mystery connectors on the rear package tray
Does anyone know what these connectors are for?
I took apart the rear of my XJR looking for a nasty rattle and found these two little beasts just sitting bare on the aluminum. I am pretty sure they are the culprit, but before I wrap them in foam tape, I wanted to check with the experts to see what they might be there for.
Thanks for any advice!
-Burt
![](https://www.jaguarforums.com/forum/attachments/xj-xj6-xj8-xjr-x350-x358-28/55741-mystery-connectors-rear-package-tray-20130922_135136.jpg?dateline=1379892472)
![](https://www.jaguarforums.com/forum/attachments/xj-xj6-xj8-xjr-x350-x358-28/55742-mystery-connectors-rear-package-tray-20130922_135106.jpg?dateline=1379892472)
-Burt
![](https://www.jaguarforums.com/forum/attachments/xj-xj6-xj8-xjr-x350-x358-28/55743-mystery-connectors-rear-package-tray-20130922_135051.jpg?dateline=1379892472)
Hi Folks,
Thanks for all the fantastic help. The schematic which U102768 posted is extremely helpful. I believe that he has nailed it. I do have the DVD system with item 14 in the rear armrest, and thus I also have item 10 in the trunk. No doubt from my use of the word "trunk", you have also figured out that I live in the states.
We do not get the TV tuner over here, although the rear seat entertainment system does still list it as an available input (nothing comes up when TV is selected). Also, I do not see either item 6 or 8 on my package tray. So, for all these reasons, I believe we have a winner!
Anyone ever try putting an ATSC tuner in these cars and hooking it up to the entertainment system?
Thanks again!
Thanks again!
Just a quick note of follow-up, I wrapped those two connectors in some foam tape and also put a little foam tape along the back edge of the package tray cover (where it looks like plastic louvered vents) and buttoned everything back up.
Good news! My rattle has been completely cured. Now I just need to figure out how to tame the wind noise coming off the right front exterior window chrome trim, which is just slightly loose. If you push down on the front corner of the trim, it will move in by about a quarter of an inch.
Any ideas besides pulling the entire car lengths worth of trim and buying a new one?
