In an earlier post, I posted I had a squirrel eat through/destroying the bundle of wires on the right side of the engine (looking at the engine from the front) just above the fuel injectors & left of oil cap. I have reconnected all the wires, BUT there are 2 black covered wires with a small tan wire inside each of them and a gold outside shield of each wire that I do not know where they go. There are no black wires beyond them to reconnect. I have attached a overview pic as well as a closeup of the 2 wires.
A shielded wire is often used to protect the internal lead from RFI or EMI. I'd take a pair of test leads with alligator clips on bith ends and connect shield to shield and the single lead to single lead then fire her up.
