Nav speaker system help
Welcome to the forum Howard Leff,
I've moved your question from General Tech Help to X350 forum. Members here with the same model will be able to help.
Hi Howard.
The phone, nav and radio have separate volume controls. It appears that sound is up and nav is down.
These outputs are all controlled via the knob, though the user must select each service to adjust their volume.
Does the music mute when the nav supposed to provide instruction?
If so, it is likely that the nav volume has been turned all the way down.
Two options to turn this back up;
1. Wait until music mutes and the nav is providing instruction-crank the volume up while the music has muted. This will raise nav volume. If I am thinking correctly, the nav is speaking, volume is too low to be heard.
2. On the screen settings for volume, select nav and use the arrow to raise volume.
Hope that helps.
-mag
Hope that helps.
-mag
