Nav touch => Separate Climate + 2DIN
Old 06-30-2015, 03:45 PM
winefan94920's Avatar
Don't have nav
Old 08-10-2015, 06:14 PM
worldrider's Avatar
@Jaguar-Moldova, great to find this thread. I am trying to do exactly the same thing.
I want to replace my NAV with a new Pioneer 2Din Carplay-enabled unit to work with my iPhone.
So I see that you've never installed the climate control unit you bought with the wires cut off? How are you controlling temperature and such? You mention in the Dash? That does seem very inconvenient.
@veffremov - I know you have lots of experience with this unit; my nav system is touchscreen and I'm considering this Carplay possibility —*I know you've designed an alternative solution for iPHone/BT integration and I am on your waiting list as this is also a consideration. But I'm hoping to install the Pioneer.
Will this be fairly easy once I figured out the climate control?
Old 08-11-2015, 08:42 AM
jaguar-moldova's Avatar
I told in previous posts that I am controlling temp and so on from my gloves compartment for now
It sounds crazy, yes.
I still didn't installed separate climate control unit I bought, cause I haven't received (found) exact answer of what I need for that.
As I understood - I need to replace control module which is under the dash.
Old 08-22-2015, 04:41 AM
I found this scheme:
Climate module connection
Also I have climate control unit with the harness and cutted wires (left pic)
https://cimg4.ibsrv.net/gimg/www.jag...17d78e963b.jpg
How can I get to know which wires are CC20-11 CC20-8 and so on?
Here is the diagram:
http://www.jagrepair.com/images/Elec...al%20Guide.pdf
Old 09-18-2015, 11:59 PM
Chris Hinton's Avatar
Where can I find this electrical diagram? I have a 2007 XJ8L with factory nav as well and would LOVE to modernize this.
Finbarr1975
09-16-2023 02:52 PM
Paora
02-04-2021 12:36 AM
Finbarr1975
10-04-2015 05:32 PM
baskervillema
10-01-2015 06:43 PM
Glenn Barickman
10-01-2015 04:09 PM
Quick Reply: Nav touch => Separate Climate + 2DIN
