navtool problem!
Hello!
Im having some problem with installing a navtool unit to my 2008 jaguar xj.
The problem is that i don't know what the different wires are doing.
i cant follow the navtool manual because the color that they say i should doesn't match the nav unit in the xj.
if you look att the picture, is there some one who have an idea how i should connect the wires from the navtool unit?
http://forumbilder.se/show.aspx?iid=dd201244316PMdd32
best regards
Erik
best regards
Erik
Hi I'm with NavTool support
Wires you need to interface are
In 26 pin connector
Pin 1 sync signal
Pin 2 green signal
Pin 14 red signal
Pin 15 blue signal
Pin 16 video ground
Red*********************** =*** From NavTool connect red wire to screen side and yellow wire to navigation side
Green****************** = ***From NavTool connect blue wire to screen side and green wire to navigation side
Blue********************** =** From NavTool connect purple wire to screen side and orange wire to navigation
Sync********************** =* From NavTool connect *black wire to screen side and brown wire to navigation
In 26 pin connector
Pin 1 sync signal
Pin 2 green signal
Pin 14 red signal
Pin 15 blue signal
Pin 16 video ground
now i have an other problem!
i have installed the acm but it doesn't work all the time. 50 % of the times it just shows disc 6 and i can not use my usb stick. have tried 2 different sticks and have just got my 4 gb kingstone stick to work but not all the time, have to turn on and of the car sometimes for the acm to recognize the usb stick..weird
someone who has an idea?
dragonfly777
Regional
09-08-2015 01:39 PM
