Need help with 2005 JagXJ8L Air suspension,ABS fault and DSC not avail .
I got all these warnings the same time. DSC not available, Air suspension fault, ABS fault and my SPEEDOMETER needle was zero. I really need help here. I have not driven the Jag since then and the rear suspension is all the way up. The front looks ok. The back suspension felt hard on uneven surface. It was cold outside. I do not know if it had anything to do with it. I live in North eastern U.S. It looks like the is too much pressure in the struts.
Welcome to the forum Koranco,
I've moved your question from X351 to X350 forum. Members here with the same model will be able to help.
When you start getting a load of faults, having the codes read is the first step in troubleshooting.
I see you've been a member for a while bit haven't posted an Intro. When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Koranco (11-10-2013)
KarimPA
09-12-2015 09:15 AM
innzane
09-02-2015 11:08 AM
