Need Help: Thumping noise in the back of the car when I turn it off
It wasn't long after the thumping sound started that I got an air suspension fault and have been having problems with the backside air suspension.
My elegant lady in her little black dress now looks like a city kid with baggy trousers hanging down the back.
I'm with P700 on this one. There have been reports in the UK of Jags where the tank has collapsed, split, and emptied its contents into the boot. The culprit is the EVAP system on the tank as under certain fault conditions it can be subjected to engine vacuum. It is an incredibly complicated system but the problem with it is that it injects (or draws) fuel vapours into the engine.
To test it though will be difficult. Just taking the filler cap off isn't good enough. It must be immediately after a (normal) run and with the engine still running. I would suggest that you remain in the car and someone else opens the filler. If it's an intermittent fault then it could be tedious to find.
I get a thump coming from the back sometimes when I stop. But most of all I've been dealing with a P442 code"small leak in evap system". If I fuel up on my way home sometimes I will have a puddle of gas on the driveway in front of the driver side rear tire in the morning. If I fill up on my way to work this doesn't happen. I do not get the smell of gas in the cabin or trunk, just sometimes outside of the car
BrentGardner
28
04-26-2024 03:08 AM
Tony K
03-26-2024 01:53 PM
Sshenton1975
08-30-2015 09:29 AM
SingBlueSilver
08-27-2015 02:20 PM
FS[MidWest]: FS: 1999 VDP *lots of pics* in mid-Missouri
souldoubt
08-25-2015 08:15 PM
