In need of specifications for emmission ! ....
Hi there,
Just joint this forum, but have been looking at it for some time now!
I'm in need to find emission specifications for a 4.2 Ltr. Supercharged 2004 to 2006 XJ8 models???
Any help would be greatly appreciated to find such!
kind regards from New Zealand - aktell
If you are after emissions outputs ive never come across that
It will also vary depending on the market as different markets have different requirements
My best suggestion is to check the NZ regs for your year model. Your car would be made to pass those. I would guess NZ uses the OZ regulations for emmissions and if you need I can point you to those
34by151
34by151
Thanks for the reply! as above that would be a great help as I can't find these.
The car (E-Type) is build newly and goes to Europe so I need the factory spec's or something like that.
thanks aktell
Ill find the links tonight and post them for you
As oz regs would go
the engine is from a (much latter) car so no check is needed
In OZ The engine should have a sticker on it with the ADR emissions code
As long as this is the same or latter for the car its fitted to, no worries
Not sure how it works in Europe maybe others can help there
Ill get you the ADR links tonight
34by151
As oz regs would go
34by151
FS[SouthEast]: Books - Various Jaguar Titles
SCMike
11-25-2015 07:55 AM
