New 2013 XJ Supercharged owner , are these fuel trims normal?l
Just picked up 2013 Jaguar XJ Supercharged
One owner car 85k miles . Black with black interior
Before going all out and doing performance ECU tune like my other Jags I Decided to run some diagnostics scans. Found out that idle fuel trims are +30 for both banks which is far from normal comparing to Denso 4.2 and 5.0 Jaguars. Can anyone confirm please? There is no check engine light codes but historic codes, photo attached...Also another issue is musky smell from vents , maybe I can get some input there as well as to how remedy this.
Apriciate it!
Apriciate it!
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
At trims of +30 you should have (trim-related) codes!
If you haven't, I guess you choose between
1. bad tool, not reporting properly
2. some reason why codes can't flag e.g. OBD monitors are unset so can't flag the relevant codes
3. er, probably some more reasons
#2 should be easy to look at, #1 means try another tool I guess
It's definitely not the monitor
Confirmed with JLR SDD dealers diagnostic, same thing high fuel terms, yet no check engine light codes which I can't figure out. All emission readiness tests pass just fine. I cant find any visual vacuum leaks. Thinking it might be maf sensors but then both of them failing at the same time is probably unlikely
