New battery goes flat 2004 XJR 4.2 supercharged its done 105K
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Hi I have a 2004XJR 4.2 supercharged its done 105K and has recently been discharging the battery I have seen threads that suggest the voltage regulator can be the problem and that to prove this on the earlier 1997/2003 models I need to disconnect the negative lead from the regulator. is there a fuse that can be taken out to prove the fault. is there anything else I can try? I have seen loads of threads for the earlier model Can anyone help please
Also understand there is a lot of complexity with various systems that will continue to draw current on these vehicles, up to hours after the you have exited the vehicle. It can be as much as 5+ amps for minutes, to up to an amp or more 40+ minutes afterwards. Every time the SCP network is called, it will reset these values and restart the clock. It should have a proper quiescent current draw test performed.
MikeyB's (09-11-2016)
Hi David thanks for your reply The battery is new and at stanby has a terminal voltage of 12.82 Volts.
When charging at tickover it is charging at 14.83 Volts.
I have been disconnecting the battery while its at home in my garage. Just checked the current drain after it has stood without the battery connected for 7 days and its drawing 2.25 Amps
You have a serious drain on that battery. Disconnect the alternator and see if it drops.
I would also check the flap in the ignition barrel is closing when you remove the key.
Does your alarm chirp work, if not then this is another possible drain.
Switch off all auto functions and check all interior lights are going off.
From a diagnostics perspective, they cannot be separated, since both affect current draw.
MikeyB's (09-12-2016)
Hi David sorry for the long delay it looks like I have an intermittent problem since receiving the advice I have carried Quiescent current tests many times some with the alarm set and some without. After about 45 minutes to an hour with the alarm set the drain is about 22Ma and without the alarm set it is about 36 mA.
I never used to alarm the car while it was locked in my garage, but have done since carrying out these tests. I am stumped but concerned that the problem will return and leave me with a flat battery without any warning. Thanks though for the advice.
meiselt
09-13-2016 02:56 PM
