new parkdistance sensors - calibrate them ?
I changed my front middle PDC sensors, as I got random beeps without obstacles being present.
Now the beeping seems to have stopped, but here's what makes me worry:
The PDC on the edges show constant signal when I move closer than 30cm.
The new PDC-sensor never reach the state of a constant signal, even if I put my hand directly over the sensor.
Both new PDC-sensors behave the same.
Are there further steps required ?
The actual controller in the trunk could be an issue?
That is what I thought when I had a problem a while ago but it really was one of the front sensors I discovered that after buying a used controller on Ebay quite cheap.
