New XJ8L
Received 9,006 Likes
Well, I took it to the local shop who did a balancing and alignment and it improved a little, but still minor vibration enough to annoy me. So it goes to the dealer on Monday for road force balancing. Even on the phone with the tech describing the symptoms, he said "bent wheel"!
They have a guy who will knock the wheel into shape!!
I will keep you posted.
Here in the UK there are now many more problems with damaged alloy wheels, due to large wheel diameters now being fashionable, (especially on Jaguars - up to 20"). Very low profile tyres are fitted to these wheels, and if potholes or kerbs are hit the tyre has no resilience and the impact goes straight through to the wheel and can damage it, but not so you would notice too much, however, it is now out-of-round, and usually scrap. In the UK the potholes are now completely out of control and appearing everywhere.
I am very happy jaguar owner today. I have been having vibration problems on my 2006 XJ VDP that has been driving me nuts!
After:
New Tires
Tires rebalanced by dealer
New driveshaft installed by dealer
Road Force Balance
the problem continued.
Stopped by a local shop today to put the wheels onto a tire balance machine again to double check that the road force balance was accurate. The tech let me watch and we saw that there was slight wobble in one of the rims. The road force balance did not pick that up!
Changed out that tire with the spare and from the ride home on wet and slushy roads I am sure the vibration is gone.
I am convinced that road force balance is a good thing, but not always reliable.
Whooo Hoooo! Very Happy.
dave b.
After:
New Tires
Road Force Balance
dave b.
I recently thought I had a bent rim on my 06 XKR, it was a 20" BBS rim. I had two tire shops tell me it was bent and that's why the tire was vibrating and pulling. I called a rim man and had him come to the house. He put it on the machine and it was not bent! The Michelin Pilots on it were bad and causing all kinds of problems. After replacing the tires, the problems disappeared. Just goes to show, you can't always look at a rim and tell if it's bent.
dmatthewman
09-30-2015 10:10 AM
'05 Gold XJ8L VDP
09-18-2015 07:15 AM
