no communication with TCM, 2005 XJ-8
Got around to retesting everything, (after I brought it to a specialist who told me the TCM was NG) found the ground behind the right front headlight had corroded! Repaired the ground and rechecked, no ign power to terminal #9 in the TCM connector. Traced to the interior fuse panel,#33, Replaced the fuse an presto!
The following 3 users liked this post by mrlakeview:
Remember I had that issue years back. Not sure if it was the problem but a bad wire ended up being revealed leading to my transmission that would blow the fuse dealing with my ECU/TCM. It cause my car to be dead in the water. One lil wire
Bluefish001
06-19-2023 02:52 PM
Canuck pump engineer
01-17-2023 07:56 PM
Fbalcazar
12-18-2021 11:35 AM
