No compression XJ6 2003 (3.oL V6)
Hello,
I have been struggeling for a while with no compression on cylinder 6. It all started when I was driving and got the engine light flashing, the error codes said missfire cyl 2&6. I changed the coils and plugs which solved the misfire on cylinder 2. However after doing a compression test I had no compression on cylinder 6, so I was thinking perhaps it is valve. However I can't find anyone with the same issues as I have, do you have any experience?
I ordered the head gasket kit and am hoping to find a way to remove the head without removing the engine, is it possible?
The Moneypit
05-02-2018 09:37 AM
