No give in rear shocks
Generally the whole suspension is fairly rigid when the car is at rest. When the car is stationary with the ignition off all four dampers go to their unenergised state which is the 'hard' setting. So, what is odd is not that you say the rear is hard but that the front is soft.
Do you know that you have standard Jag air suspension units on the front, or have they had some form of coil spring conversion fitted ? Most conversions seem to have single setting dampers; some of those have electrical connections to fool the suspension module into thinking it has switchable dampers when it hasn't (otherwise it will continually report a damper fault).
KarimPA
09-12-2015 08:15 AM
OkieTim
09-08-2015 04:48 PM
Tar
09-06-2015 11:24 AM
