RH fuel level sensor circuits, open circuit
RH fuel level sensor SCP message error
RH fuel level sensor failure
Check REM for flagged DTC
The Engineering Test Mode will indicate many of the vehicle DTCs however it will only show faults detected during continuous operation and not self test faults. Because of this it should not be considered as a replacement for an OBDII code reader required to read the standard DTCs.
The codes are presented in hexadecimal format, the Most Significant Bit will be a number or letter 1,9,A,D or E, followed by 3 Decimal digits.
The first hex digit corresponds directly to the DTC code identifying the system related to the trouble code.
1XXX relates to Enhanced (manufacturer specific) codes P1
9XXX relates to Body Enhanced (manufacturer specific) codes B1
AXXX relates to Body Enhanced (manufacturer specific) codes B2
DXXX relates to Undefined (manufacturer specific) codes U1
EXXX relates to Undefined (manufacturer specific) codes U2
The last 3 digits are in Decimal and relate directly to the DTC code. i.e D900 = U1900 which is a CAN bus fault.
The numbers can relate to a number of different problems (like the example above) so should only be used as a guide. The use of a DTC code reader is the best way to recover diagnosis codes and information.
You should also be able to see this code when you go into the Engineering Test Mode on the instrument cluster. Hold down the Trip button on the Indicator stalk and turn the ignition to position 2, keep holding for a few seconds and then release. You should see the various information in the message center under the speedometer. Cycle through by pressing the button on the indicator stalk. If that code shows up then it's gotta be related to the fuel level sensor.
have a look here http://jaguar.bttlxe.com/xtype/Addit...%20Cluster.pdf in the X350 XJ section, #15 "DTC's" and also check #22-#26 it gives you the values for the fuel measurement, if any of those are maxed out then it's a sign that the fuel level sensor is duff.
So if I read that right, it's just related to the fuel level sensor, which is no surprise. Our fuel gauge works only when it feels like, and has since we've owned it. It was a rather spendy repair so I just reset the trip odometer whenever I fill up to know approximately how much fuel is in the tank. Usually when the tank is below 1/4 it starts to register correctly, so it was never worth fixing.
You said it's got the code B2139 - Engine control module identification does not match instrument cluster. Possible causes: Reconfigure instrument cluster
If that's what's causing the no-start (which it certainly looks that way) then the problem is that you cannot reflash the Instrument Cluster if there are other errors, like the fuel level gauge being open-circuit.
Except it appears the reflash was successful re: B2139
I cleared the DTCs and did a refresh and now I have NO DTCs listed under Related Events with Selected Symptom being 'no start, cranking speed normal'
It's still a mystery why I get the red message center light, but no corresponding message.
Just a random thought, check the emergency fuel cutoff switch in the a-pillar?
I checked it several times over the course of this, but out of curiosity I used the datalogger to check what the system thinks the inertia switch is communicating.
It says the switch is "ON", but I can't tell from the schematic if that is 'cut off power' or 'power ok', so I tested Fuse 1 in the cabin fuse box and it is getting 12v so I'm assuming that "ON" means 'good to go'...?
Then checking fuel; pressure at the rail? (you should be able to see this via OBD or in the datalogger of the SDD) are the injectors firing?
And then spark, not sure how you would check that with a coil-on-plug setup...would putting a timing light on the coil wiring pick up the pulsing?
As I mentioned before, the REM isn't grounding the fuel pump, so there is no fuel pressure at the rail. Both the Red and Yellow wire coming from the REM going to the fuel pump test at 12v. One of the two has to be switched to ground for the fuel pump to function.
The problem is does the REM have a burnt transistor (that it didn't have when this all started) that is preventing it from grounding the pump, or is the ECM telling it not to run the fuel pump?
Playing with the datalogger, trying to see what signals the ECM is sending the REM, I get the following:
Fuel Pump Duty Cycle to the REM - 74.9%
Modulated Fuel Pump Duty Cycle - 75%
Fuel Pump Duty Cycle 2 - 0%
Is that 0% problematic? I have no idea and I'm trying to research it, even though I have no idea what Fuel Pump Duty Cycle 2 might be.
Ah yeah I forgot you mentioned the fuel pump not running earlier.
Seems very unlikely that the ECU would not be telling the REM to run the pump, since the communication is over the SCP network, you would have all or nothing. Unless the REM itself has an internal problem like you say, maybe something burnt.
I think you already checked it, but what about the fuel pump relay, fuse and diode in the Rear Power Distribution Fuse Box?
EDIT
I also think that it's no co-incidence that you have a problem with a fuel level sensor, as well as the fuel pump not running, and both of those are controlled by the REM.
Yes I checked, but I did again anyway. Fuse 33 in the Rear Power Distribution box measures 12+v, so the relay and diode check out.
EDIT
I'm sorry I wasn't clear. The fuel level sensor has been intermittent for *years*, and is a well known fault with first year production cars. There was a warranty TSB to fix it, but the previous owner obviously never got it done and by the time I got the car it was out of warranty. So I think we can ignore that.
Reason: I'm tired and make mistakes
Let's say that the Ford values also apply to Jag. IF the ECU is really telling the REM to not run the fuel pump, then the question is, why? There must be a reason why...
If the RECM isn't turning the pump on, any chance the car has immobilised on purpose (but wrongly/annoyingly)? I think you'd see some P1xxx code(s) in the PCM.
