is this noise a failing radiator fan?
Evening all. I have a loud rattling sound coming from the front of my 2004 XJ8 Sport. It sounds plasticy, so im guesing, possibly, that its the radiator fan - perhaps wearing out. I was hoping someone might have experienced similar and may be able to confirm, or maybe diagnose something else. The noise only happens once the car is up to operating temps.
I've just taken 2 video clips. the first with engine running. unfortunately its not quite as obvious in the clip - its much louder in actual fact. But you can just hear it along with the engine noise. it sounds like a ticking in this clip.
in the 2nd video I turn the engine off and you can hear the noise carry on for a few seconds before it stops. I thought it sounds like a whirring noise, which is why i thought the fan.
(temp gauge sits where it should at all times and no coolant loss)
any insight would be greatly appreciated.
Dani
Dani
Regarding the noise, I also cannot identify it.
Best regards,
Thomas
started car from cold. no rattle.
turned on AirCon. rattle started after a few seconds!
turned AirCon off. rattle stopped after a few seconds!!
thankyou for that, so looks like the fan/shroud assembly is the source of the rattle. Unless it can come loose and something needs tightening. Doesnt look like theres much room to work around the radiator area so might end up taking to the garage. But i'll take off the top cover when i get a chance to see if its something i can do myself....
Thermite (09-24-2024)
This sounded like a very easy thing to test, so....
....i'll take off the top cover when i get a chance to see if its something i can do myself....
Bad things can transpire if/as/when a fan sawblades itself though a wiring harness or fluid plumbing hose.
Bit of PBSL, you might get by with nowt but a few minutes of yer time and a zip-tie or two?
nerf (09-25-2024)
Just to close off my thread. I took the car to my mechanic and the fan bearings have been diagnosed as the noisy fault.
I had a secondhand one bookmarked on autoreserve but unfortunately that sold a few days ago, so if anyone has any suggestions where i could get a decent SH fan unit that would be great...
cheers!
cheers!
FrankZ06
08-05-2021 09:44 PM
