Non-OEM air filter?
I am trying to save a little $$ by buying a non-OEM air filter. The NAPA and Purolator ones I have looked at are too big, although they supposedly are drop-in replacements.
Does anyone have the correct part numbers for a NAPA, FRAM or Purolator engine air filter for the X350?
I started with Napa Gold Wix #2261 for $14, but it seemed too big and when lined up next to the old filter, that was confirmed so I went to the dealer but the $26 filter they had was too big too and looked just like the Napa.
Well, as it turned out, for some reason the old filter was too small, even though it looked like a perfect fit. The new filter has to be squeezed into place apparently.
HI there, I also have a 2005 XJ8L and bought a Beck-Arnley cabin air filter replacement and found it is larger than the filter installed there…so, to confirm, the only replacement you have had luck with is from the Jaguar dealer? Thanks for any additional help.
xjrjag
09-27-2015 01:53 AM
1964Daimler
09-09-2015 11:28 AM
