Is this normal idle speed??
Mine does a similar rev at start, but I would have to review it specifically to tell you if its in the exact same range as yours (1300-1500) - It then idles at 600 on the nose in drive (according to the tachometer) I am not 100% sure, but I feel as if my car revs a bit higher after I cleaned (or partially cleaned) the throttle body. It was truly black around the butterfy plate, and on the engine side of the plate, and even though I had some quality 3M Throttle Body Cleaner, I don't feel as if I got it as clean as I would like.
It's since that operation last weekend that it 'seems" to rev a bit higher on startup, but that could be imagination. I have only owned the X350 for a few weeks, but the 4.0 Liter in my X308 also reved on startup. I am pretty sure its working as designed.
Anyone know a thorough way to clean up the intake? I cleaned my airbox and replaced the filter - I also have run 2 containers of Chevron Techron (treats 12 gals., so I use 2 per tank 2x. I am afraid to use any more for thinning the oil with the stuff. (I am considering a K&N, but want to make sure people aren't reporting dirty (as in oil covered) MAF sensor with a K&N in the airbox - On some car designs its a real problem. Anyone?
aholbro1
08-05-2021 05:02 AM
PlatinumJag
20
10-02-2020 02:23 PM
Thang Nguyen
10-12-2015 01:25 AM
Johnken
09-15-2015 05:46 PM
