Now that's odd!!!
Hi all.
I own an 04 XJ8 SE and have been getting the following messages;
Air Suspension Fault.
Gearbox Fault.
Check Engine light amber.
All of the above mentioned have been displayed over about a four week period at one time or another. They disappear of their own accord so I couldn't understand what was going on. The car runs fine and all looks OK. However, I suspected that the battery may be at fault at first but then I altered the way I start the car. What I now do is insert the ignition key, let the seat and stearing wheel adjust automatically, then start the engine. Hey presto, since doing this I have had no messages at all so I suspect that starting the engine whilst the seat and stearing wheel are moving causes such a drop in voltage that it fools the car into thinking it has a fault.
Anyone else had the same?
Happy motoring. Les.
Gearbox Fault.
This could absolutely explain my Air Suspension Fault message as my dealer tech did not find anything wrong with the suspension system and gave the car back to me without touching it (except that they did fix an air bag problem which was apparently a lot more serious than I thought it was). I'll have to give your method a try and see if anything happens for the next few weeks.
But what I wonder (really) if what this really means is that we need new batteries?
Guest
Posts: n/a
I've been searching the forums to see if anyone has the same experience as me. The other day I was coming up the highway and the odometer turned over to 60k. Very nearly after that then engine light showed up amber and I assumed it was just telling me the 60k service was done. It went off the next day.
Then last week I pulled into a very steep driveway, about a 30 degree slope. When I did that the dashboard lit up like a Christmas tree.
Gearbox Fault
STC Fault
I turned the car off and let it sit for a while. When I turned it back on everything was clear.
What the heck? Do I need to go get a scan to see what kid of codes are in the memory? I'm new to Jag ownership so any help is appreciated.
Gearbox Fault
STC Fault
belawidi (04-29-2014)
Agreed Fraser. Belawidi, here's the bulletin that identifies the possible entry points. Always worth checking to ensure it's unrelated to electrical gremlins.
mikiep
12-20-2019 07:37 PM
philwarner
28
07-11-2017 10:21 AM
