odometer rewind
odometer rewind
Hi Everyone
My 2004 Jap Import XJ8 has a speedo in km/hr but the odometer reads miles. My local Independent specialist has a used mph speedo. However, the mileage on the car is 54,000 and the replacement unit shoows 118,000. Is it possibe to re-programme this to 54,000mls?
The Instrument Pack is a programmed module. I know from needing a replacement for an XK8 that swapping them is not straightforward - it has to be both compatible and programmed.
Changing the dial insert is an easier option. Here's an example:
www.lockwoodinternational.co.uk/c1730.html
avoids reprogramming and much pain.
nurquhar
10-30-2012 03:40 AM
