OEM oil filter
From the research I have done over the years I would suggest you do not use a basic Fram oil filter. I suppose some (myself included) have used them at one time or another, but for a expensive (Jaguar) or high performance type on engine, they do not have a great reputation. Fram does make a high performance filter that has ample filtration and bypass ability but they are not known for their high quality filters in the low cost area, especially compared to other filters. Before you buy any of the ones not suggested above (or even for the ones suggested) you can google oil filter construction and various check out quality issues. The Fram may do just fine and does in fact work for many users but for the $$ I personally would use any of the others suggested first. Wix or Bosh may even make the OEM filter for all I know. I do know that Jaguar does not have a oil filter division. However they probably do have exacting specifications for their filter since almost every aspect of their engines are tight tolerance/clearance and almost high performance. Compared to other mass produced engines that is.
Personally, I have been using nothing but the factory OEM engine oil filters on my 2005 Jaguar XJ8L. In fact, I have been obtaining mine on eBay from a place located in California, Including shipping, the oil filter for my vehicle will run around $20.00 USD which is more or less reasonable. For an expensive and high performance car like this, I wouldn't dicker around with the after market filters.
Partick the Cat (05-06-2018)
Don B (05-06-2018)
Received 13,425 Likes
The original oil filters may have been made by Visteon, a former division of Ford (the original air filters were marked Visteon and packaged in Jaguar boxes). But I agree with Box and abonano that the oil filters Jaguar currently supplies are made by Mann and are excellent filters with both a non-return valve and a bypass valve. For many decades Mann has been an OEM to Jaguar, as well as BMW, Mercedes, Porsche, Audi, Volvo and other major automakers. Rock Auto offers the Mann W 713/29 for $14 and our local NAPA stocks them for $20.
Cheers,
Don
Cheers,
Don
Sonspit
33
10-20-2018 08:18 PM
1FastCat!
09-29-2017 05:54 AM
al_roethlisberger
02-07-2017 07:59 AM
Flying Finn
30
12-20-2010 08:14 AM
cincinnati
General Tech Help
01-31-2009 08:51 PM
