Oh Boy Suspension Fault: C2780. She seems to be sitting a little high?
Hello Everyone,
Well my new baby has a main issue I want to tackle right away.. The Suspension fault message is showing on the cluster and the scanner revealed a C2780. I did a quick search and it seems that the suspension needs to be recalibrated? It seems to be sitting a bit high.
Do I need to use the JLR SDD tool to recalibrate the Suspension? Unfortunately I don't have this tool. I own an Autel and I have access to a professional Snap On Scanner. Can either of this scanners handle the recalibration (if that is what is needed)?
Thanks!
Thanks!
Hello Everyone,
UPDATE
My brother tried setting the suspension with the Autel. It let him choose between Transportation Mode or Customer Mode. It was set to Transportation Mode, so my brother changed it to Customer. He didn't notice any difference or change in suspension height. He did not drive the XJ.
In addition the the C2780, codes B1671 and U2521 codes from the air suspension module.aka DSC (Dynamic Stability Control Module).
Where/what would you recommend we check/do next?
UPDATE
These cars are extremely sensitive to battery voltage being even a tiny bit low. I had stuff like cannot set parkbrake, cruise not available, and a sometime wonky temperature gauge, none of which has happened after getting a new battery.
That doesn't mean a new battery fixes all you're seeing, but even marginally low voltage can trigger very weird things.
Thanks Everyone. I should change the battery just a precaution since these cars are sensitive to battery voltage.
UPDATE.. my brother took at the tape measure and measured from the center of the center caps to the apex of the wheel openings.
Front: left 350 mm right 320 mm (factory setting is 386mm)
Read: left 400 mm right 378 mm (factory setting is 373 mm)
What steps would you do to breakdown the issues? My thinking
1. Spray ALL air fittings with soapy water to check for leaks.
2. check ride height sensors(how do you check)? but wouldn't that of throw a specific code?
3. valve block by air tank defective?
4. check of the CAN circuit on the DSCM (hence the U2521 error code; thanks BigKoshka) ?
I'm also just curios what causes a C2780 to trigger?
Sorry if random with my thoughts, just thinking out loud.. I don't mind doing diagnosis work to narrow the problem.. I'm not a big "fire the parts cannon guy" but hey sometimes we have no choice lol.
thanks!
thanks!
I'll preface this by saying I'm no expert on the air suspension, but have done some reading here & there.
Is C2780 the only code showing? If so that just means its in transport mode. You tried switching it back to customer and nothing? Do you know what the previous owner had serviced on the suspension system (sensors, replacement struts, etc)? Did he try anything to resolve it that you know of? Did this happen right after replacement of a component?
I would start with a good battery charge and then a hard reset on the battery and see what happens. With no other codes and the car sitting high I would doubt there's a leak, so possibly ASM module issue. If it were a level sensor I'd assume you'd get a code for that.
Hello! and thank for the feedback.. Well after setting the car back to customer mode my brother didn't drive it, so not sure if the heights will reset. I just bought the car a few days ago so I don't know if the history, but it seems to me the original owner kept up on the maintenance and the college kid who bought it and kept it for a 6 months did not...
I may change the battery for good insurance and clear the codes with the Autel. Then see what happens... The passenger front did seem low so maybe something going on there... I think the car was sitting high because it was in transport mode, but now it was changed.
Lets see what the weekend brings. I keep everyone updated. Maybe my little issue helps someone else.
I really wish I had a JLR SDD. I need to find a way to get a cheap / hacked version.
Thanks.. happy riding
OMG! lol my twin brother. Mine has been in a few more brawls in its life lol so lots more dings and scratches, but hey we're still brothers. Congrats on your baby. looks amazing!
Next two items are 1) TPMS: all the sensors seem bad. I'm looking to use the JLR SDD and just shut off the TPMS system. Problem is I don't have the JLR SRR tool. so researching on how to get a cheap cracked version. 2) I also have a P0128. The code is right on because the coolant gauge is acting funky. Seems like the thermostat is stuck wide open. I think I'm going to buy the whole octopus unit(Thermostat housing) but not sure If I'll just change just the thermostat housing portion of the octopus or the entire unit... I'm researching now on how to do the job.
Today a quick interior cleaning and leather conditioning lol
Happy riding
Happy riding
Maya404
08-08-2019 07:18 AM
