which oil
Old 06-09-2014 | 01:17 PM
ozbod1's Avatar
Default which oil
hi, im about to do a gearbox oil change do i need special oil? if so can someone point me in the right direction? im guessing normal atf wont be much use? thanks in advance
Old 06-09-2014 | 03:48 PM
trosty's Avatar
All that information and a plethora of other XJ8 related information can be found in the "How To" thread at the top of this forum. Hope that helps.
Old 06-09-2014 | 04:23 PM
Fraser Mitchell's Avatar
The cost of the correct stuff is eye-watering and if a proper flush is done, the shop have to use more than the gearbox and torque converter hold in order to clear all the old stuff out. Essentially, some of the new fluid flushes out the old. The well-regarded Jaguar specialist that did mine in 2012 used 10 litres @ £15.50 a litre. New sump assembly which includes the filter cost £95. Good thing it is only required every 50-60k miles !!
Old 06-09-2014 | 04:28 PM
abonano's Avatar
X350's - ZF 6 speed transmissions call for Lifeguard 6 - there is a cheaper option - Motorcraft Mercon SP fluid - again, as mentioned - flushing will be necessary (repeat drain/fill) - you can expect to get only 6 liters in when entire unit holds north of 10 liters.
Old 06-10-2014 | 08:08 AM
Partick the Cat's Avatar
A local transmission company offers two fluids: Lifeguard, or Pentosin (cheaper). They say most people opt for Pentosin.
Old 06-10-2014 | 10:31 AM
Mikey's Avatar
What year car do you have?
Old 06-11-2014 | 06:41 AM
ozbod1's Avatar
thanks 2003
Old 06-11-2014 | 08:37 AM
reyesl's Avatar
Question
thanks 2003
Do you have an X308 or an X350? They have different engines and transmissions. The X308 has the 4.0L with a Mercedes 5 speed transmission and the X350 has the 4.2L with a ZF 6 speed automatic.
MrWhite
19
06-14-2022 08:49 PM
Dave1109971
12-15-2015 07:16 PM
3jagfamily
10-01-2015 02:49 AM
Woznaldo
09-26-2015 12:02 PM
ahunt4
09-25-2015 04:43 AM
Quick Reply: which oil
