Oil change questions
If it is similar to mine, a 2005 XJR, you have to take off the undershields. The front undershield to get at the filter and the large middle one to get at the plug.
Took longer to take of the shields than it did to do the oil and filter change.
Then its easy.
I bought a filter from Carid on Ebay. Not the cheapest and not the most expensive and I used synthetic 5w 30 oil.
Then its easy.
StellaLunaGardens (11-30-2016)
Thank you!
Then its easy.
Then its easy.
Oil capacity
I don't have an owners manual, and I'm having a hard time finding out how much oil I need to add, when I change it. Thank you!
StellaLunaGardens (12-12-2016)
Handbook link
Forum sticky no help? https://www.jaguarforums.com/forum/x...ownload-10582/
I've posted the link to the 2008MY X350 Owner's Handbook JJM 10 02 21 802 before but here it is again:
http://www.mediafire.com/file/q8t53o..._02_21_802.pdf
Oil specification is on page 218:
An oil of 5W-30 viscosity to Jaguar specification WSS M2C913 - B must be used in all vehicles with a petrol engine. For top up purposes only, where the WSS M2C913 - B specification cannot be found, ACEA A3/B3 or ACEA A1/B1 specification oils may be used.
Oil capacity is on page 219
V6 engine, including oil filter: 6.5 litres (6.87 US quarts)
V8 engine, naturally aspirated, including oil filter: 6.0 litres (6.34 US querts)
V8 engine, supercharged, including oil filter: 6.8 litres (7.19 US quarts)
The following 2 users liked this post by GGG:
Don B (12-13-2016),
StellaLunaGardens (12-19-2016)
