oil leaks
oil leaks
03 plate xj with the v6.engine fitted.
Smell of burning oil which i put down to the cam covers leaking onto the exhaust.
Two new cam cover gaskets fitted.
Left the under tray off to clean it off and see if there are any other leaks .
Getting drips off the two bolts for the alternator and a couple of drips off the air con bolts.
Not jet washed it off yet, curious to see what the most common point of leakage after the cam cover gaskets could be?
Sump gasket, the plate at the front of the sump or the crank seal?
jag79
02-25-2016 01:14 PM
