Oil sump pan bolts
This part is cheap, so you should get it from the dealer if one is close by, or can also be found at your local auto parts store. Here is a link to the part: https://www.napaonline.com/en/search...=semantic&se=1. You can also check your local Autozone and O'Reilly.
Thood691 (11-18-2020)
Thank you for your reply. There is not a dealership close nearest one is about 2 hours away. I went to auto zone this morning but when they looked up what I needed they could only find transmission bolts. Also when I use the link you left the only ones that come up that look close say these don’t fit your vehicle. Dose anyone know if it’s a good idea to use the original bolts cause I’m having no luck.
NBCat (11-16-2020)
Received 2,679 Likes
Thank you for your reply. They are being removed because there is a leak coming the gasket. She’s getting close to it’s next oil change so I was just hoping to get this knocked out to so I dont have to check the oil every 2-3 days. I had read that another member had ran into a problem with one of the bolts breaking When being torque down ( not sure if it was a x350 or not ) so that was a problem I’d like to avoid. But if people say they have reused there’s I’m just going to do that. I had also called 2 mechanic shops to do it and one said there not interested and the other said the don’t like working on jaguar but they quoted me about 400 in labor. It’s seems like a pretty simple job so I was just gonna do it myself.
So basically put all bolts in, finger tight then torque them down per spec in pattern.
Get OEM pan gasket from Jaguar and PS this job is very simple.
Maybe 30 minutes tops and most of that is cleaning the groove in the pan and block surfaces w/ brake cleaner.
Make sure pan surface is square as it may be warped if pan was repeatedly over tightened in an attempt to stop the oil weep.
No sealant required on rubber gasket....
For a few $ there are tools to measure the thread dimensions, then off to the hardware store
There are two sets in my tool box, the S A E thread's still widely used, & mixed in with metric, on occasion.
The other set is Metric, & British Whitworth, combined, one set, on each end.
The S A E set, has more sizes than the other two combined.
Where could I probably find this manual the only ones that are in my car are the regular owner manual and audio manual and a passport to service.
I doubt any of the bolts will break upon loosening. As NBCat says follow torque sequence, which BTW I think the spec is very small, like 9 ft lbs.
thank you for your reply. I do wish it was that easy but this car is my daily so Once’s I have the bolts in hand I have no car to get to the hardware or auto parts store. Thank you for the help though.
