Overcharged! Too Much Freon? XJ
My AC was cold but not cold enough so i tried to add air conditioner from auto zone, it was showing in the green range on the gauge but i added a little bit more and its now in the red. Today when i drove my car my AC is worst, its not cold, is there anyway i can takeout some of the freon!
kchirume (07-12-2013)
Received 9,006 Likes
What temperature have you set on the console ? Eventually, the degrees figure changes to 'Lo'. The cooled temperature has to be above freezing to stop the evaporator from freezing up with ice.
JimC64 (07-13-2013)
You would need some re-engineering, and are limited by available space, the shape of that space, and the airflow to and from it.
The most basic trick is to change to a larger and/or more thermally efficient heat exchanger coil set for the condenser side of the circuit. Copper, for example, has roughly triple the conductivity of the more commonly used aluminium. That said, even a more conductive tube and fin array still has to get enough air over it to take advantage.
There just have to be at least a few specialists who do modifications of luxury vehicles for the Oil Potentates of the uber-hot Middle East and as well as the US South West, Mexico and South, parts of Asia.
The experts are out there, even if more familiar with Hummers and the like than Jaguars.
is there any chance of dirt and fluff clogging the cabin filter or the evaporator?
I had mine recharged today, they sucked out 600g of old refrigerant and put in 800g back to full, didn't seem to me to make much difference. It is hotter than usual here. the tech said he measured the cold at 6.6C which seems pretty cold, but the interior stayed above 17C while I did a couple of 5-mile journeys. It is rather hotter and sunnier than usual here at the moment but I don't think it has been above 32C outside.
The car maintains a comfortable internal temperature, but, if I let it, blows hard when I get in after it has been parked in the sun. I find opening the windows for a minute on the blipper cools it down fastest.
p.s.
it cost me £49 incl refrigerant and oil. ($75US). I wouldn't bother DIYing it.
p.s.
Well I guess I should be happy that I live in NH! I would suppose that someone could design either a larger condenser coil or perhaps increase the size of the cooling fan to allow better Freon cooling. That may not be the limiting factor but it would be in the right direction. I believe a larger cooling fan may be the easiest approach to investigate.
RyeJag
RyeJag
Here in NJ its been real hot, 98 to 104 with heat index hitting 120. I roll down all four windows and open the roof for the first two minutes when I start off and roll them up when I feel the duct blowing cold. I think the system works very well and I have a black interior. It makes me think Kchirume has a problem some where in his system and does not need to reinvent the wheel.
Rigsby94
05-10-2012 09:20 AM
Jeff96
08-15-2011 10:16 AM
