Overhead console wood trim fix?
So, pretty simple problem, but a workable solution defies me thus far.
I should start with the fact that I live in Phoenix, AZ... if you've never been here, it's hotter than a blast furnace on the surface of the sun...
The battle, is to get the overhead console's wood trim to stick to the plastic bit that it fits into... The stock sticky tape stuff has completely lost its sticking power, and what I can only assume are plastic clippy things that should hold it in also are bent just enough to mean they don't grab the plastic...
I've tried industrial strength (via Home Depot) double sided exterior house tape, but it isn't holding it... I don't want to glue it, as that piece is obviously SUPPOSED to be removable to some extent, but not such that it just falls off.
Does anyone know what the factory sticky stuff is? I would like to try and replace the stuff on there...
Anyway, I'm open to ideas... it's always fun to have that "sky is falling moment" every couple days where it falls down on my lap or the passenger's while driving, very embarrassing when it's someone else in the car...
Thanks for the input though, I'll use it if glue ends up being the way to go.
I have the same exact problem on my XJ 2008 VDP, but my piece is only hanging on the drivers side. I can see the slot for the clip latch, but it is useless. There also appears to be some sticky residue when pressing it back into place.
I used 3M Bumper/Trim tape picked up at AutoZone. There is a wide variety of widths and types.
I used the same tape in my overhead console as I used on my chrome rear lamp bezels.
Here is the link to selections of the 3M tape. I used the 3M™ Pressure Sensitive Primerless Acrylic Foam Tape 5849, Gray, Red Printed Liner, 20 mil
3M Automotive Trim & Accessories : 3M
Just use a small piece in a spot(s) you will remember, so if you need to remove, you can pry at that spot and will not crack the trim.
Hope that helps.
Cheers,
Chris
Hope that helps.
Cheers,
Chris
Hope that helps.
Cheers,
Chris
Hope that helps.
Cheers,
Chris
aholbro1
08-05-2021 05:02 AM
280zx-turbo
09-10-2015 06:29 AM
