Overheating
Overheating
I just spend hakf day reading every piece of related information but couldn't find an answer.
New pump, new rad, new thermostat, new temperature sensor to no avail, it still overheating
Even after removing thermostat every time it idles for 5 minutes, temperature is in red zone.
It's in the middle for as long I'm driving
Fan is working even after shutdown for 5 minutes and no errors to grasp what is going on.
Any ideas where to start looking for solution/
Any ideas where to start looking for solutions
As I've mentioned
There is no thermostat now.
As soon car on its way, in less than 100 meters needle move to the middle. Heater and AC are working.
You will know that heater is working as soon you stop and needle is in red, blower pushes hot air and
after car moves, it goes back to AC cool.
The idea of being able to remove the thermostat in the hot summer weather.
Worked fifty years ago, but no heat when it got cold it got reinstalled.
You used water straight from the tap, no need for antifreeze in the summer.
You could overheat, blow a hose, or break a belt, and loose it.
But the cooling, fuel systems, & motors were all much simpler then.
Your thermostat is no longer just an option for your heater to work
Thermostat is out for now to test if it causing problems. After all here in Canada
winter can start tomorrow. But thanks for advice guys.
We're trying to solve this for more than 1 month now and after replacing virtually
everything including all hoses, we're not an inch closer to solve this mess.
As I said there is nothing in fault codes to grab the string and without starting point,
I afraid my guesses are as good as yours and at least there is someone who have
experienced the same problem and successfully fix it, would be capable to provide
solution and hopefully could give helping hand.
As previous Posters have mentioned, your Jaguar will not run correctly without its Thermostat. The Stat is a sort of 'two way' valve, allowing coolant to circulate within the radiator only to cool it quickly, then switching to around the jacket to cool your engine.. ...You will overheat without it!
I write from personal experience?
It doesn't work correctly regardless if its in or out.
Having unrestricted flow at least removing one of possible reasons not to mention that
the main purpose of thermostat is to regulate warming up time in the winter.
Oil is OK and engine is working like a Swish clock
Again, overheating is happening only when car is in parking mode.I can drive all day
and as long I don't stop for longer than 5 minutes, I have no problems.
Something else is going on here obviously.
It sounds like you have tried a bunch of stuff. My only other thought is have you validated the actual voltage coming from the temp sensor? You replaced the sensor, but have you checked the voltage reading? If all of what you are saying is true; flow is good, a bunch of stuff has been replaced, no bad head gaskets, then honestly the only other thought is your sensor is bad or the ECU is reading the sensor incorrectly.
Have you validated the temps coming in and out of the radiator? I am not sure off hand what those should be, but it can certainly help show if the overheat is real or not. You can also check various other hoses to see what those temps are.
