I'm receiving the following codes after a 2 hour highway trip:
----Pending Trouble Codes Scan Report----
3 Pending Trouble Codes Trouble Codes:
1. P0128
Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
2. U0132
Lost Communication With Suspension Control Module "A"
3. P2601
Coolant Pump "A" Control Circuit Performance/Stuck Off
Does anybody have any ideas what could be causing these three errors? Do you know if they may be related?
As 06-XJR mentioned, electrical faults such as low battery voltage, corroded ground points or electrical connectors can cause spurious fault codes. If it were my car, I would clear the codes and see which, if any, recur.
Regarding the codes you pulled, note that Jaguar's definitions and possible causes often vary from the generic definitions at OBDII code websites, and not all codes were implemented by Jaguar. Also, generic OBDII scanners sometimes misinterpret Jaguar codes.
Here are the Jaguar definitions and suggested causes, per the X350 DTC Summaries manual:
You codes look OK as my 2005 workshop manual gives the same causes:
Does your temperature gauge decrease below the middle line when going downhill or no load? If so, your thermostat seal has failed and could cause a P0128.
The other two, rightly or wrongly I usually reset them and see if they reoccur.
