P0171 Code Resolved
p0171 troubleshoot what first exhaust smell
If I do smell exhaust from the upper driver side engine bay, where would you trouble shoot first? the joint between the manifold pipe down to the Cat Converter connection? Put a spacer there?
it's a P0171 bank 1 lean that stayed on and restricted performance goes away at higher speed. Thanks!
03 S type R
picture from my mechanic
03 S type R
My 2004 XJR has been troublesome area with lean fuel trims. The MAP sensor is a critical part of the fuel trim . My car runs best and code free with a DENSO mb197400-3021 sensor. I have replaced numerous parts to fix the lean code, including hoses, o rings, EGR valve, Throttle body and done fuel injector cleaning.
RyeJag
RyeJag
rentzoo (10-19-2023)
RyeJag
RyeJag
Abe Mirza
07-19-2023 08:53 AM
noterman
08-18-2016 08:11 PM
