P0327 error code help
Old 10-04-2020 | 05:58 PM
Timspong's Avatar
Default P0327 error code help
P0327 EMS
OBD II
Bank 1 KS sense circuit out of
range – low voltage
Start engine
Battery voltage > 12 volts
Idle for 2 minutes
2 A ECM Default:
– Maximum ignition retard
– Maximum engine speed
reduced
PI1
-098
Poor sensor contact with the cylinder block
KS to ECM sense circuit short circuit to ground
KS failure
This is the info on this error code. Does anyone know the likely source of the short circuit or continuity break. could it be as simple as a rusted ground wire or something?
thanks for any help or opinions - My car is a 2004 xj8 and it is currently in performance restriction mode because of this error I think.
Old 10-05-2020 | 06:30 PM
meirion1's Avatar
There was a post on here very recently showing the location of a connector
on the top of the engine where the KS can be tested.
It could well be just a faulty KS which is just a coil and
has gone open circuit.
Found it!
https://www.jaguarforums.com/forum/x...nk-1-a-237617/
Old 10-11-2020 | 04:14 PM
Timspong's Avatar
Nice thanks
Chris Benyo
04-28-2020 02:45 PM
nickdabs
02-21-2020 06:59 AM
mosesbotbol
11-18-2012 02:10 PM
dailmer
07-27-2012 10:29 PM
tcbjaguarxjr
03-31-2010 05:14 PM
Quick Reply: P0327 error code help
