P0414 Error Code on a 2006 XJ8L
![Unhappy](https://www.jaguarforums.com/forum/images/icons/icon9.gif)
![Icon Couch](https://www.jaguarforums.com/forum/images/smilies/icon_couch.gif)
It has no effect on engine performance. My mechanic turned it off but it came back on. He said something about air input into the exhaust and it might be an air valve. We looked for a valve or solenoid. What and where could it be located? Could an air supply pipe to the exhaust be broken? If so, where in the world would I start looking for the problem? Help, Please.
![Icon Hunter](https://www.jaguarforums.com/forum/images/smilies/icon_hunter.gif)
Try posting on the X350 forum. My XJ6 throws the code occasionally and it's for the secondary air pump which supplies air to the exhaust system under startup. You can check the thread below, but I'm not sure if it applies to your car.
https://www.jaguarforums.com/forum/x...-p0411-149884/
Received 12,932 Likes
Hi Terry,
I have moved your thread from the forum for the X308 to the forum for the X350, which is the Jaguar factory project code for your 2006 XJ8L.
The P0414 Diagnostic Trouble Code doesn't show up in the DTC Summaries manual, but it shows up as P041400 in the Workshop Manual, which you can download in six sections free from this forum:
http://www.mediafire.com/download/md...f+contents.pdf
http://www.mediafire.com/download/aa...nformation.pdf
http://www.mediafire.com/download/n3...2.+Chassis.pdf
http://www.mediafire.com/download/9b...Powertrain.pdf
http://www.mediafire.com/download/0i...Electrical.pdf
http://www.mediafire.com/download/4j...+and+Paint.pdf
P041400 is defined on pdf page 1931 of the Powertrain section. It indicates a problem with the Secondary Air Injection Valve electrical circuit (not necessarily a problem with the valve itself). To diagnose the cause, the manual refers us to Pinpoint Test G528708p4, which begins on pdf page 1942.
You may also want to download the 2006 XJ Electrical Guide, which is available free here:
http://www.jagrepair.com/images/Elec...al%20Guide.pdf
Cheers,
Don
Cheers,
Don
AD2014 (09-23-2015)
Thanks for bringing this up, JagV8. I had intended to and forgot. I have revised the thread title accordingly.
Cheers,
Don
'05 Gold XJ8L VDP
09-18-2015 07:15 AM
FS[SouthEast]: 2006 and 2007 Jaguar Media Press Kits
SCMike
09-09-2015 09:30 AM
