P2097 & P2099 Engine Codes
I was getting engine codes stating I had Faulty O2 sensors P0420 and P0430. Changed all 4 O2 Sensors at once.
Now I get P2097 and P2099 codes without any other companion codes. At this point the car has a slight driveability issue as it surges upon take off from a stop light and when in park at an idle the RPM surges up and down about 50 to 75 RPM.
I have an ELM 327 that will give me all the engine data live time what indicators should I be looking for?
I have in the past six months rebuilt the intake with all new gaskets, replaced all spark plugs.
By what I understand that it cannot adjust to add enough air to compensate for the incoming fuel to the system; bad fuel regulator possibly or bad fuel pump?
Any help and suggestion would be greatly appreciated.
Thank you,
Joe Walma
Thank you,
Joe Walma
They are related to the old codes I bet. https://www.obd-codes.com/p2097 and https://www.obd-codes.com/p2099 - fuel trim codes.
I'd start by monitoring fuel trims using that scan tool.
Superb explaination here:
I believe 02 sensors age with time and new sensors are
very sensitive.
It can take quite a long time and many miles for them
to settle down.
very sensitive.
to settle down.
