Park Brake Fault - 05 Super V8
Old 07-04-2012, 12:36 PM
kozdi's Avatar
Default Park Brake Fault - 05 Super V8
Hi
I replaced worn pads on EPB. My mistake is that I didn't check service manual and just simply replaced old pads with new, retracted pistons & reinstalled everything. Engine from EPB is running but once you put it in park it stuck every single time. To avoid unnecessary questions (I checked already all thread)
- Battery is in good shape it is not battery fault. Low voltage can give PBF
- I tried to recalibrate it how it is suggested in service manual. Didn't help.
Do I need to replace pistons cause I damaged it or do I need to go to dealer and maybe they can just connect it to computer and recalibrate system.
Right now I just simply disconnected lines that go from engine to pads so I could drive. Please advise.
Kozdi
Old 07-05-2012, 05:22 AM
Fraser Mitchell's Avatar
Received 2,451 Likes on 1,949 Posts
Sounds like you have the Brembo brakes as you have a separate park brake caliper. I am not sure the service manual re-set instructions cover these calipers, can you confirm. If they do, it sounds like off-to-dealer time.
neruda
10-18-2015 01:19 PM
Safari
US Central
09-21-2015 09:34 AM
metalmarty
09-11-2015 07:05 AM
motorhead69
09-09-2015 10:04 AM
Quick Reply: Park Brake Fault - 05 Super V8
