Park Brake Fault - New Topic
To make a long story short. Had the park brake fault, took it to dealer, says it needs the park brake motor. No deal. Motor has been unplugged, calipers removed, cables tied up. Decision made.
Now, any techs out there know how to fool the computer (whichever one that might be) into thinking the EPB is OK and killing the fault indicator in the dash? I installed the coil over suspension and added a resistor in the harness behind the rear seat to fool the suspension computer so I'm fairly certain the same type mod would work on the park brake. I'm sure someone knows how and where. Can you help me? Thanks in advance.
![Icon Worthy](https://www.jaguarforums.com/forum/images/smilies/icon_worthy.gif)
Depends on what is wrong with the actuator.....if it is the hall effect sensor, you could leave everything in place and it should still engage and disengage manually....but if you disconnect the motor and have full inspections where you are, you wont pass, they usually require that the parking brake hold the vehicle while in gear at idle
Hadn't thought of that, but here we do not have inspections. As HhisIII mentioned, it did engage manually I believe, but then one morning it locked up and wouldn't release. I smoked the pads for 10 miles to get home. Cost is not so much the issue as access. I can barely see it, much less see how to get it out. Just not motivated to try to R&R it. I've just replaced the entire suspension, switched to coilovers, front wheel bearings and I'm just not interested in doing this job and certainly not paying the dealer to do it. Thanks for everyone's thoughts, though.
Received 2,263 Likes
neruda
10-18-2015 01:19 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
