Parkbrake fault after pad change RESOLVED
Received 13,347 Likes
Cheers,
Don
Every have any luck with this? I have basically the same problem. Worked fine prior to battery going flat. Charged battery and park brake fault appeared. Done all of the troubleshooting I can. See this thread.
https://www.jaguarforums.com/forum/x...-230053/page3/
Does the "Apply Footbrake" warning appear on your instrument cluster? Typically after the battery is disconnected and reconnected you have to depress the brake pedal and operate the electronic park brake and the warning will go away.
Cheers,
Don
