Parking Brake Calibration.
2004 VDP
replaced both parking brake cables as they were chaffed.
initially parking brake stuck on
Managed to clear codes
now no parking brake but have parking brake fault on display.
I think it needs a recal, but it refuses to
question........to recap,,,,,,do I need to back the pistons back as far as they will go.....and then recal........before I start stripping everything down......is that what the problem is.......
or am I missing something.........mechanic thinks actuator motor may be binding up........but its a bitch to get to......and friggin expensive........can only find ones on eBay.......2nd hand.......which I don't trust.......and Jag want nearly 600 bucks.......
anyone got any ideas........
The best way to get to it IMO is to cut a hole in the spare wheel well and patch it afterwards.
You can then access the holding bolts.
Get it on the bench and investigate from there.
Maybe try a hard reset first.
Also ensure that the mechanism in both calipers is working but I can't tell you how.
Parking brake calibration is done by pressing the service brake a few times, holding, and pulling the parking brake button. If that doesn't work, may be other issues. The calipers don't need the pistons wound back in, has no affect on PB calibration. PB just pulls a lever on the caliper the same as pulling a handle in the car.
rsa760041 (05-11-2020)
