parking sensors troubleshooting
Hello All,
i found a good info recently about detecting faulty parking sensors.
since several weeks, i have a long beep from parking assist each time i put either D gear or Reverse. after the long beep i also got the red light above my head on the central console parking assist button.
i deducted one of my parking sensor was gone.
problem is which one ?? there are 8..
i found the following info on the web that i tested and seems working.
with engine OFF but ignition key on, you put the gear on reverse.
then you touch gently each and every sensor with your finger doing small circles on the surface.
you should feel some pulses on your finger . when you dont feel anything this means the sensor is Dead.
i will change it today and let you know
have a good day
thierry
have a good day
thierry
AD2014 (06-08-2015)
Received 13,203 Likes
[QUOTE=Jagfrenchie;1242584with engine OFF but ignition key on, you put the gear on reverse.
you should feel some pulses on your finger . when you dont feel anything this means the sensor is Dead.[/QUOTE]
Hi Thierry,
Another method is to place your ear close to each sensor. Working sensors produce a soft "clicking" sound. Dead sensors are silent.
Have you checked the new sensor you replaced to confirm that it is pulsing or clicking? If it isn't there may be a problem with its wiring harness.
My rear right sensor is dead so I'm going to have to follow your lead. Any tips will be greatly appreciated!
Cheers,
Don
Hi Thierry,
Cheers,
Don
AD2014 (06-08-2015)
Guy-Pierre Boucher
09-16-2015 05:55 PM
adam699
09-12-2015 05:32 PM
KarimPA
09-12-2015 08:15 AM
