Parrot Bluetooth Installation
I'm looking at installing Bluetooth in my 2004 XJ8. I'm currently looking at the Parrot MKi9200 and installing the screen where the ashtray is and removing the ashtray. There seems to be a lot of room there. Has anyone used this setup and have pictures of how it turned out? I haven't been able to find any installation pictures in any of the other threads. I'd rather not have wires showing everywhere.
Also, I saw parrot also offers something called the Parrot Unika that allows you to use your steering wheel controls. Has anyone installed this module?
Amazon.com: Parrot Steering Wheel Mounted Control Interface for Parrot Mki/RKi: Cell Phones & Accessories
It mentions being compatible with all CAN-bus vehicle communication protocols. I was just curious if it would work with a 2004 XJ8.
Thanks,
Eric
![Amazon.com: Parrot Steering Wheel Mounted Control Interface for Parrot Mki/RKi: Cell Phones & Accessories](https://www.jaguarforums.com/forum/images/misc/amazon_icon.gif)
Thanks,
Eric
I don't know the Parrot, but I put my Motorola T605 in the ashtray. it is hidden beautifully, but at the same time, access is poor and really bad when using the cupholder.
I don't know about the steering controls either, sorry. Overall I found the bluetooth works well and mutes the stereo, etc.
esloser (06-20-2012)
I fitted the earlier Parrot CK3100 in my last X308 and then transferred it to the subsequent XK8. My current XK8 has Jaguar Bluetooth but I must say it's nowhere near the quality or features of the Parrot.
If I were going for a Bluetooth installation, the Parrot MKi9200 is the one I'd go for based on this experience.
From reports I've seen elsewhere, steering wheel interface suppliers take a rapid step backwards once you mention Jaguar so you may have to compromise on this facility.
Be interested to see how you progress with this.
Not to say it couldn't be done but you may have to do much more than jockey a few harness connections.
Hi Eric,
I've attached some photos of the MKi9200 installed in my 2003 X350 XJ6. The screen and remote are positioned under the ash-tray cover (which still closes fine hiding the whole thing). The screen fits nicely behind the chrome ash-tray surround and the remote fits in front of the cigar lighter - as long as you replace the lighter element with a 'blank'.
The Parrot blue control box sits behind and below the radio/nav unit - there's plenty of room there and it wires into the car's loom easily with the right adaptor cable from Parrot. Make sure you get the right one - if you have the Alpine upgrade it's a different adaptor - check the Parrot website for the part numbers.
I ran the iPod lead from the blue box, underneath the centre console and made a hole in the bottom of the arm-rest storage compartment as shown in the third photo. I also installed a 12v socket in the forward storage compartment (I removed the cup-holders) so I could plug in a separate charger for my iPhone.
The microphone cable runs behind the glove-box, up the A-pillar and around the top of the windscreen behind the headlining to the microphone sited above the rear-view mirror.
The system is brilliant - completely hidden, no wires showing, very easy to use with the remote falling nicely to hand and excellent sound quality through the standard Jaguar speaker set-up.
I hope that helps - good luck!
The following 2 users liked this post by peterjameswass:
mikeclarke (08-29-2018),
Richj (08-10-2012)
Hi Peter,
Thanks for the photos. I didn't realize the Parrot screen would fit inside the ashtray surround. I was thinking I'd remove the ashtray. Did you do the install yourself or have it professionally done?
I don't have the Alpine system in mine, so that shouldn't be a problem. Thanks again for the feedback. Did you try to mess around with the Unika system at all? Or, did your research lead you to the incompatibility information.
Thanks again for your help,
Eric
Eric
Hi Eric,
I did the install myself - it's pretty straightforward and this thread https://www.jaguarforums.com/forum/x...-photos-50454/ helped me a lot in terms of removing the centre console and getting to the back of the radio/navigation unit.
The screen fits nicely inside the ashtray - you need to remove the chrome surround (it's just clipped on) to route the screen cable into the ashtray itself but you can clip it back on okay. I've not fixed the screen - rather it's held in place by a square of foam (covered in black sticky-backed plastic) sitting behind it which pushes it against the front of the ashtray surround. This makes it easy to remove if you need to reset the Parrot unit for any reason.
I did a bit of research on the UNIKA compatibility but in the end it was as simple as checking on the Parrot website - the screenshot attached shows the result.
I hope the install goes well - if you have any questions do let me know and I'll try to help out.
Peter
Peter
Hi Peter,
That installations looks great, I have been told that it wasn't possible to fir a 9200 into the X350 with the Sat Nav screen audio system ?
Obviously it is, what exactly did you need for the installation, re adaptors etc, and does it not have to integrate with the audio gear at the back of the car ?
Very interested in this as I used a 9200 in a friends Audi, and it was a great bit of kit.
Thank you
Russell Swift
Thank you
Russell Swift
Hi Russell,
The installation was pretty simple. My car has the sat-nav and 'basic' audio system (as opposed to the optional Alpine upgrade) and it was simply a case of plugging the Parrot adaptor cable between the loom and the back of the navigation/audio unit. There were no connections needed to the audio kit in the boot.
If you go to Parrot - Installation diagrams for installed Bluetooth hands free car kits and enter your car's details you'll see which cable you need and how it all fits together.
Good luck!
Peter
Good luck!
Peter
mikeclarke (08-30-2018)
A good tip is to push the wire between the various trim panels using a plastic tool so as not to damage anything - a plastic picnic knife or spoon will work well.
Good luck!
Unfortunately, I have an XJ6 X350 2003 with the premium ALPINE sound system inclusive of rear amp... today on the 30th August 2018
Parrot TECHNICAL have informed me that it is not possible to install it on this system. DEVASTATED!
This being the second advice received as the day before I received the same comments from COMPLEX SOLUTIONS that it is not possible on the premium sound systems with separate amp.
SO THERE YOU HAVE IT.
