Pause between stopping and starting
In my new-to-me '04 VDP I have noticed that when stopping, as if for a quick stop for a stop sign, and immediately going back to the gas pedal, there is a slight pause before the transmission engages. Not a long one, no more than a second, if that, but its there. In the old days (I'm old) I would think I'm either waiting for it to shift back down to first or the fluid is low. My car is low mileage but 13 years old and has never had the fluid changed, to my knowledge. I think I should go ahead and do a fluid change, certainly won't hurt anything. What do you all think? Have I a problem or is this a common trait to the ZF?
On my Super V8, the gearbox always shifts to 1 when the speed decreases to a few mph, even if not stopping completely. Cold or not.
Il is barely noticeable, at first I thought it was an issue of warped brakes that induced this slight "braking", then I realised it was the gear shifting.
On the other hand, when accelerating, the gearbox shifts from 1 to 2 quite early unless I floor the pedal. Maybe the memory of my usually cool driving stored in the TCM.
And I don't think it's due to a bad oil level in the gearbox, the gearbox works very smoothly and the oil was changed only 2 years ago.
Thanks paydase, I guess what mine is doing is nothing to worry about for the time being anyway. I guess it's just a quirk of the ZF.
Thanks to everybody for the help and reassurances, ride safe!
![Icon Pala](https://www.jaguarforums.com/forum/images/smilies/icon_pala.gif)
May be a quirk but changing the fluid solved it for me. Change the fluid. What you're experiencing isn't normal.
Don B (06-26-2017)
Thanks for the advice, I think a trans fluid change is good PM too.
