Pedal adjustment
I think it's time to pretend, unfortunately.
Cheers,
pearlfisher (08-16-2012)
When the gear splits the worm drive jams on the teeth across the split into two the gear. I was successful in grinding down one tooth that provided enough clearance for the worm to then engage the next tooth. I had this problem 10k, and 6 months back and no further issues. It is a pain to working upside down getting the assembly out.
xjrguy (08-25-2012)
I know exactly what you are talking about, as long as it stays greased up, I'll bet you'll get a good bit of life out of that.
Thanks!
I think it worked once, and now I can hear the motor trying to adjust to the three different driving positions. The steering wheel adjustment still works.
JJ
JJ
jimforrest (uk)
02-28-2019 06:42 PM
