Pesky P0101. MAF sensor or something else?
Hello Everyone,
Recently I've been getting a pesky P0101 code, but only in a very specific driving condition. I'll be coasting downhill on the huge mountain highways of PA...... barely applying the throttle, hence the low absolute throttle position %. Very happy with my fuel trims and the engine is running perfectly, smooth as silk.
Is there anything, other than the MAF sensor, that I should be looking at? I installed a Delphi MAF senor 17K miles ago when I was getting a P0101, but that time the fuel trims were higher and increase as the engine went under load ( a sign of a bad MAF sensor). Could it have gone bad already? I was thinking of purchasing a Denso unit. I was going to check the resistance of the signal wire on the MAF harness, but got lazy.
I'm hoping there are people more skilled at interpreting the freeze frame data than myself or experienced the same problem. Misery loves company.
Thanks so much.
Thanks so much.
I'll be no help but I will be watching this thread in hopes you find the solution. I have had this same problem for years, I can reliably trip the code doing exactly what you described or just by having the cruise control on in the hills of PA, a drive I make regularly. My indie Jaguar guy gave up trying to resolve it, I do believe it is MAF related as it seems to happen slightly less frequently after a good MAF clean but I've never found a way to fix it permanently.
Well the new Denso has been ordered and I'm really hoping it will solve the issue. I also going to install a new air filter, as well, since its been 17K miles since the last change.
BRGSuperV8, yeessss it only happens to me on those huge mountain hills on rt78. The car runs perfectly otherwise. I already downloaded the pinpoint tests from ALLData for the P0101 and the wiring diagrams. I usually run all the tests first before firing the parts cannon at the car, BUT I'm hoping my laziness to test doesn't cost me lol.
I'll definitely post the results!
Update: I've installed the new Denso and unfortunately pulled the P0101 code twice in 2 months. The good part is that I drive a LOT and for the most part the car drives perfectly and excellent fuel trims. I'm going to leave as is for now. I don't even reset the code, it actually goes away after 3-4 start ups after pulling the code.
