phone system
Guest
Posts: n/a
Well I bought a Jaguar, Wow nice car.Here is my problem,although a small one. I have thew phone system but no phone was in the car when I bought it. I did some reserch and came up with a v60i motorola is the phone that was in the car., however it is a analog phone and no one will connect it. I did find a v60s phone with gps digital I bought it stuck it in the car. I got it working a couple times. It was great when it works. I seem to have a bad connection ar something else is wrong. I have checked contacts. when you plug phone in it goes to charge which i believe its suppose to do. then on the touch screen it says phone off. I push turn on and I get a check phone error. It will not turn the phone on. except the couble of times I got it working by moving the phone up slightly and then setting it back down. I don't know if I have a phone cradle problem or something else.Help
when those cell phone kit's were installed the cradle's wud always wear out prematurely.. the wire pinches between the cubby box and the console... just follow the wire into the cubby box.... everybody has updated to the bluetooth setup.. im not sure if jag even sells the cradle anymore,
Guest
Posts: n/a
thanks for the info i called the jag dealer you can still get a cradle 295.00 . I guess that would be my best bet. no guarentees though. they also confirmed what you are saying about the trouble with cradles. its either that or conversion to bluetooth 1500.00 thanks agian
Yeah, def. fix it and you're very lucky it came with the system alone even if you had to buy the phone! My 7 series(standard) came with a motorola car phone we just leave in there and use all the time its real nice to have. I was very sad to see the bluetooth option at around $2k with installation for my hand held in the StypeR.
kosta013
12-06-2019 10:27 AM
