Plastic Hex Nut and Jaguar Hood Ornament
I have a 24 mm socket, but it was not deep enough to fit (as you've experienced). I used a pair of linesman's pliers, but any longish set of plier with wide-ish flat ends will do. Insert, find the surface of the nut and twist. It should not be in super tight (doesn't need to be really). Hope this works.
jeff
jeff
