Please tell me what these 3 parts are called
What item 1 is, I haven't a clue, but obviously it's a pipe of some sort. A photo from further away may give a better clue.
Item 3 is the rear tie rod that controls toe in/out of the rear wheels. I had to have new ones eventually on a 2003 X350. Normally it is the bush at the outer end that fails. Not toooo expensive: -
https://www.ebay.co.uk/itm/154101312...Cclp%3A2047675
The following 5 users liked this post by xalty:
Colm O (06-02-2021),
Don B (05-26-2021),
Leslie Graham (Levitikon) (07-04-2021),
rsa760041 (06-07-2021),
the brain (05-24-2021)
I found No 3 at only 30 quid each but the brand I never heard of, LCP, and can't even find a manufacturer called this
https://www.ebay.co.uk/itm/264524037...2Cchnl%3Dmkcid
should I stay clear? :-)
https://www.sngbarratt.com/English/#...20tie%20rod%60
You can rely on the Lemforder one, and the official Jaguar one is probably a Lemforder one anyway, with Jaguar kissing it up the a*se with a big percentage add-on for the Jaguar-labelled box.
if it’s before around G29000 there’s a chance it never got recall j012 done and they’ll fix it for free. obviously the car is gonna sit on their lot for like a year because nobody wants to do that job, but hey it’s free
if not, he’s in for a ride
By the look of the corrosion, he shouldn't hold his breath for a free replacement, it's just a brake line.
Why the brake line concerned me, is that some years ago (on a Non-Jag Non-ABS) I had a brake failure due to corrosion at the wrong possible time. Came within inches. Didn't have time to "pump the brakes". But I swear I warped the chassis with my pressure on the brakes.
so after replacing the rear stabilizer bars and drop links, i took it for wheel alignment. Im in spain so having a hard time communicating with the mechanic, but from what I could understand he said the left rear wheel was straight but seemed to lean in at the top, heres the wheel report..
he said it could be a silent bloc? if anyone has any advice im all ears. Could it be a fault with the air suspension? as i drove it to get aligned there was a fault with air suspension coming up on the dash when i didnt have it before, i thought it would go away once the wheels were aligned. well i assumed that. strange how i didnt have the fault before i replaced these drop links and stabilizer bars
bad bushings on the lower wishbone will give you extra negative camber. your left side is probably toast
his sheet is looking at the specs for an X308, tell him to look for 04 and up or an s-type as reference. i think they’re about -1 from the factory
