Pliers found hanging from left tie rod
Hello everyone;
This is why you should not trust mechanics and always try to do the job yourself when possible.
i heard a noise coming from the front left tier rod and it happened to be a Plier found hanging from the front left tier rod .
A mechanic replaced the intake manifold gasket, Thermostat assembly, return manifold coolant hose and knock sensors and apparently forgot his pliers, then obviously it dropped down to the bottom of the jag hanging from the tier rod.
Find pic attached
Don B (05-08-2019)
While we were just discussing in another thread the tendency of repair shops to overcharge and do unnecessary work, I think its unfair to generalize in this case. **** happens and the home mechanic is just as likely to misplace a tool or goof up a repair somehow, probably even more so just because we don't do it all the time. I was working on my 1966 Mustang quite some years ago and despite that I thought I was being extremely careful in all things, using fender protection, etc., I forgot and left a ratchet lying on a shop towel on top of the air cleaner while I went to the workbench to work on something else. Sometime later I decided I was done for the day, shut the hood and put the cover on the car before heading to the house. Next weekend I took the cover off and realized I'd put a nice outward dent right in the middle of a brand new, freshly painted hood. If a shop had done that, I wouldn't have had to pay for it. Just be thankful for a free pair of pliers. I got you beat though. I once found someone's Snap-On brand 10mm swivel socket in an engine oil pan. I've used it several times.
Don B (05-06-2019)
Received 10,988 Likes
Don B (05-06-2019)
Received 13,425 Likes
I haven't lost any of my Snap On, Mac, Cornwell or Matco tools, but I lost one of my favorite Craftsman U.S.A. 10mm 6-point sockets somewhere on top of the AJ26 in a friend's XK8. I suspect it's wedged somewhere in the valley, but since I had already done the thermostat, valley hoses, etc., I probably won't get a chance to pull the intake manifold anytime soon.
Don
Don
If I know that I've misplaced a tool or something, I try my best to find it and retrieve it, worried like the OP that it might work its way into a spot where it could interfere with the operation of the car or even worse, make a rattle that would drive me crazy. I'm really bad about carrying a tool or part away and setting it down somewhere. For example, I might need an o-ring and so I'll go over to the parts bins and set my ratchet down while I look for the correct size. Then I'll need some PAG oil and I'll go over to the cabinet (and maybe set the o-ring down there). Then I'll go back to the workbench to get the compressor, etc., etc. By the time I get back to the car, ready to install the compressor, I have no idea where I left the ratchet and I spend the next half hour searching the engine bay and then the rest of the shop. I have been known to tear an engine back down again looking for a missing bolt, but its frustrating because I sometimes don't find what I think I've lost until after I've given up and it appears while cleaning up the shop after the project is done. More frustrating though is starting the next project and only then discovering a tool is missing. I've tried to get in the habit of putting my tools back where they belong in between tasks even if its only going to be a few minutes till I need it again and that helps, but I still occasionally lapse. We really should do like a surgeon, make a list of everything used during a project and check to be sure everything has been retrieved before we button it up, but then I'd probably spend half an hour a day searching for my pencil.
Don B (05-08-2019)
I repair Old Rolls Royces and Jaguars but I also have my A&P so accounting for tools is a good way to avoid liability issues.
When I attended classes for my A&P I was advised to NOT mark or identify my personal tools for obvious reasons.
If a tool became 'missing' from my tool box, the rational was to replace the tool ASAP.
The anecdote is that as soon as the aircraft leaves the repair facility and crashes upon take-off, the repair logbook will fall onto the runway with the relevant page open to your last repair (Murphy's Law) and a pocket screwdriver with your name on it will be found next to the wreckage.
bob
bob
For some reason....a total mystery to me....I simply cannot keep 10mm sockets. Darn things are constantly escaping my custody.
My problem isn't so much losing tools, per se. But, rather, keeping track of them. I seldom have fewer than 4-5 cars in some stage of repair at any given time. I have tools in or around all of them. When I find myself spending more time looking for tools than working on the cars I take an hour or so and get everything gathered and sorted.
Don B (05-07-2019)
Doug (05-07-2019)
Don B (05-07-2019)
bob
bob
But I used one of those electric engravers to mark many of my tools in case they got stolen. I also maintain an Access database with an inventory. Speaking still of not remembering tools, a friend of mine had his rollaway tool cabinet stolen out of his garage, filed an insurance claim and then went on a shopping spree to replace his tools. Over the next several years, every time he started a new project, he'd have to go buy a tool that he was sure he'd previous had but forgot to list on his insurance claim. He remembered all the major tools that were really expensive or that he used frequently, but forgot probably several hundred dollars worth of minor tools like that 11/16" offset wrench that he'd bought when he had a Ford and only used once. I wanted to be sure that if my stuff was ever stolen that I'd have an inventory and the law would have evidence to prosecute if they happened to catch the perpetrator. I never thought about having my initials on a socket that falls in the wrong spot and binds a brake caliper.
Don B (05-08-2019)
muttony
08-21-2022 06:59 AM
dianebauman
04-26-2019 04:08 PM
Samkpg
04-12-2019 09:50 AM
