POP goes the Air Strut
I know this subject has been beat to death on here, but i have a technical question... I was driving around yesterday (luckily 1000 feet from my driveway) when i heard a loud POP. The front of the car sank. the front Passenger (america) side had blown the boot off where it connects to the top part of the strut. The metal band which held it on was no where to be found. The rubber/plastic boot seems to be in ok condition, What i am wandering is, is there such thing as Replacement Bands or do you think a large generic hose clamp and some sealent would be strong enough to handle the pressure? Ive already ordered a new Strut from Arnott but if i could fix it i would love to save that $550.
Any opinions?
after i repositioned it
lcmjaguar (05-29-2015)
I think youre right, I put a hose camp on tight. They didnt have a correct size cv clamp like the one that came off... Anyway when i lowered it down and started it up, it was still leaking tremendously from somehwere. I couldnt see since the wheel was back on but it must be some internal injury. I changed a Rear over to Arnott right after i baught the car so ive probably been living on borrowed time running the other 3 oems.
Yes, the outer tapered plastic gaiter is just a dust cover. The actual air spring bladder is mostly inside the metal cylinder. You can see just the lower end of the bladder in your photos. Arnott claims to use Goodyear replacement bladders, but so far no one has learned if we can purchase bladders directly from Goodyear. If you figure out a way, please let us know!
Cheers,
Don
OEM Bilsteins here at David Manners, a UK supplier of many years. I say this because I used to use them when I was rebuilding a Mark 2 in the 80s. As I lived in Birmingham, they were conveniently placed. No on-line internet ordering in those days !!
Jaguar Partno_C2C41347#_F. AIR SUSP DAMPER X350 >G35210_David Manners Group with Alts
They also have Jaguar-sourced Bilsteins for nearly double the price. Why pay more ?
Fraser, I think you're right, but at the time they were refurbising air springs/dampers they claimed to be using Goodyear bladders. It would be great if someone could discover how to purchase these bladders directly from Goodyear. The steel clamps appear to be similar to those used on CV joint boots, but may perhaps be stronger. The tools for tightening that type of clamp are generally available from racing suppliers.
ThyssenKrupp own Bilstein, and you can see Bilstein on the label, so I would think it is an OEM unit installed sometime in 2011-12 by the owner at the time. It's puzzling to see a Unipart part number on it. Maybe Unipart supply Jaguar with spares.
ThyssenKrupp Bilstein - Home
Fraser,
I ran across this press release while researching Jaguar OEMs. Unipart runs at least one of Jaguar's parts distribution centers/centres:
http://www.unipart.co.uk/UserFiles/F...stpractice.pdf
Note that the Unipart number on Bobby's air spring/damper is just the prefix 02 added to the Jaguar number.
Cheers,
Don
Guy-Pierre Boucher
09-16-2015 06:55 PM
Chuck Schexnayder
09-12-2015 11:30 AM
34by151
09-06-2015 06:14 PM
